Je cherche à retracer l'histoire des cables Hp Naim. En particulier, quand est apparu le Nac A5 et y avait il un autre câble avant le Nac A4 ? A l'achat de mon Nait 1, mon vendeur m'a offert une paire de cables HP censés être les cables d'origine, mais ça ne ressemble pas du tout à du Nac A4. Je suis preneur de toute info.
En fouinant sur le net j'ai trouvé cet article de 2011 de Richard Dane, l'administrateur du forum Naim officiel. Je ne connaissais pas la préconisation de ne pas mettre le système entre les enceintes, mais plutôt sur le côté ou en face...
Naim amplifiers do not have extra inductance networks in the output, Naim prefer to use the speaker cable to provide the correct inductance and capacitance.
To do so a minimum of 3.5 metres of NACA4 or NACA5 cable is required – although the optimum is around 5-10 metres. We find the supplied Naim speaker plugs to be an optimal match for the 4mm sockets we use on our amplifiers.
In addition, the plugs are designed in such a way as to prevent them being accidentally inserted into European mains sockets - hence the warning in your Owner's Manual
"The Naim loudspeaker connectors supplied are designed to comply with European safety legislation and must be used."
Cable length for left and right channel should be of exactly equal length – even if one speaker is closer (as is often the case) to the power amplifier.
It is advised that you position the system away from between the speakers, either off to one side of the room or at the opposite end. As such, longer lengths of cable are ideal and will work without significant information loss.
Spare speaker cable should not be coiled – excess cable may be tidied up in a way similar to that employed in the “Jumping Jack” firework. Examples can be seen in this thread:
http://forums.naimaudio.com/topic/cable-dressing-6
Use cable ties or similar at either end to hold in place.Additional: I would not recommend any particular length for the folds - you can make the folds suitable for hiding but use some sense. You are most likely to end up with one cable needing to be tidied - that to the nearest speaker - giving the distance between the speakers as the amount to be dealt with.Avoid having the doubled (tripled or whatever) too close to either the speaker or the amplifier end of the cable - to give as much flexibility as NACA5 allows for the final run at each end.
Avoid running the cables parallel to mains cables.
Apart from Naim's own upgrade cable - Super Lumina - alternative speaker cables cannot be recommended by Naim, however, should you still wish to try them then you should ensure that the cable is low capacitance and of moderate inductance. High capacitance cables are to be avoided at all costs and may result in damage to your amplifier.
NACA5 specifications are as follows:
Capacitance: 16pF per metre
Resistance: 9 milliohms per metre
Inductance: 1uH per metre
Minimum length: 3.5 metres per channel
Maximum length: 20 metres per channel (note that longer lengths can be used up to around 25 m but then some small signal loss must be expected
Câbles HP Naim, Histoire ?
- jyhacqua
S1: ND555 - NAC552 - NAP300 - MD3
S2: WIIM Pro - Dac Lavry DA11 - Linn LP12 (Armageddon/Akito/Adikt) - Nait 50 - Naca4 - Leedh Starlett
S3: WiiM Pro - SuperUniti - Leedh Psyché
S4: NDX2 - CDX - Philips SA963 - Technics sl5200/Ortofon Red/Rega fono - 52 Supercap - 135
- Naca5 - Linn Sara
S5: WIIM Pro+, NAC42, NAP110, Linn Sara
S6: Naim Mu-so 2
- Naca5 - Linn Sara
S6: Naim Mu-so 2
Re: Câbles HP Naim, Histoire ?
Il existe bien des câbles ayant des caractéristiques similaires au Naca5...Mais les fabricants ont de la peine à donner les caractéristiques de leurs câbles...pourquoi? A part quelques-uns, DNM par ex.
Mais en parcourant les forums UK, on voit vite quels sont compatibles...Chord, Ecosse, Atlas, Silent Wire, Qued, etc.
Mais bon, la sonorité change, pas toujours en mieux...on gagne ici, on perd là...où est le juste compromis? Devinez?
Avant le naca 4, ce qui remonte au début des années 80, je ne me souviens pas de câbles préconisés par Naim. A cette époque les électroniques Naim étaient fréquemment branchées sur des enceintes Linn qui était partenaire source et enceintes, les enceintes Linn étaient câblées en intérieur par du câble Rouge et du Noir; en cas d'achat d'enceintes Linn, Il était possible d'obtenir ce même câble en grande longueur pour relier les enceintes aux amplis, c'était un câble électrique cuivre d'assez gros diamètre sans caractéristiques particulières et d'utilisation général. La stabilité des amplis naim a été mise en cause avec l’apparition de câbles HP, plutôt assez haut de gamme, recouvrant des propriétés électriques spécifiques convenant bien à certaines électroniques et enceintes, d'utilisation moins universelle.
- jyhacqua
Ça expliquerait les câbles "d'origine" que m'a fourni mon vendeur.ALMO a écrit :Avant le naca 4, ce qui remonte au début des années 80, je ne me souviens pas de câbles préconisés par Naim. A cette époque les électroniques Naim étaient fréquemment branchées sur des enceintes Linn qui était partenaire source et enceintes, les enceintes Linn étaient câblées en intérieur par du câble Rouge et du Noir; en cas d'achat d'enceintes Linn, Il était possible d'obtenir ce même câble en grande longueur pour relier les enceintes aux amplis, c'était un câble électrique cuivre d'assez gros diamètre sans caractéristiques particulières et d'utilisation général. La stabilité des amplis naim a été mise en cause avec l’apparition de câbles HP, plutôt assez haut de gamme, recouvrant des propriétés électriques spécifiques convenant bien à certaines électroniques et enceintes, d'utilisation moins universelle.
- Naca5 - Linn Sara
S6: Naim Mu-so 2
- Naca5 - Linn Sara
S6: Naim Mu-so 2
- jyhacqua
Un autre article du même Richard Dane sur Naca 4 et Naca 5 :
A bit of history:
NACA4 was a Naim design and was made for Naim by BICC. Unfortunately due to an alleged change of staff and premises, BICC thought it was their design and started to supply a similar cable to other manufacturers, including Linn.
When it was pointed out to BICC that they were effectively supplying illegal copies of NACA4 to other manufacturers, the case was settled out of court in Naim's favour. According to Naim's Julian Vereker, "We then spent the money on designing a new and better cable with another supplier under a secrecy agreement, and this is the NACA5"
Incidentally, JV reckoned the insulation on the illegal copies was different (a softer material?) to NACA4 and hence performance was not identical.
A bit of history:
- Naca5 - Linn Sara
S6: Naim Mu-so 2
- Naca5 - Linn Sara
S6: Naim Mu-so 2
Un lien qui explique comment réduire la longueur des câbles HP sans nuire à l'ampli!
http://www.pinkfishmedia.net/forum/show ... p?t=165366
