Naxo, Snaxo - réglage, entretien
- Nac-nap21
Petit rappel pour les utilisateurs de système actif qui constatent un déséquilibre entre fréquences graves et aigues ou dont la balance du préampli est décentrée. L’opération 1 est à répéter de façon assez régulière.
Version anglaise pour ne rien perdre :
"I strongly believe that finetuning your SNAXO to the room is very important and have done it many times now. It is beneficial to do it every time something changes on your system.
Once you are experienced, it is nothing to fear and can be accomplished confidently. Below is my methodology that I wrote on a previous thread.
"This is what I do; no Naim advice / dealer training. I have developed this over the years and it works well for me**. I find a re-set every time a new component arrives pays dividends, whether because I am optimising it within the system or simply just by the rotating the pots I clean things a little? I even found optimising the pots when trailing different Superline load plugs was beneficial.
First, mark the pots starting position before you start with a fine point felt tip marker.
1] operate all pots up and down between max and min several times to clean the contacts.
2] put all pots down to minimum
3] move lh bass pot to approximately mid way round
4] put balance in dead centre, pre-amp in mono
5] choose a piece of music with a strong repetitive bass line at your normal listening level* and sit in your listening position [make sure the listening position is exactly repeatable since you will be getting up and down quite a lot!]
6] adjust rh bass pot until the both bass channels are exactly equal [when it is right you will know, drums will “pop” evenly]
7] choose a piece of music with nice female vocals
8] disconnect rh bass driver speaker leads
9] adjust treble until the balance between bass and treble on the lh speaker are correct
10] disconnect lh speakers bass driver
11] adjust rh treble to match lh treble, match my any ssss on the vocals until perfectly even [again, when it is right, you will know, everything sort of clicks into place]
12] plug both bass drivers back in
13] fine-tune if necessary over the next few records / days**
14] don’t forget to switch back to stereo when you’re done
This is what I do and I find it works very well. If you find you can’t get it right, move the pots back to where you marked them and at least you know you have tried…..
* so you get the “room effect” at your most common volume setting
** you will find that different bass notes can/do excite the room differently so the bass might need fine-tuning until there is a nice compromise across your typical music choices"
I hope this helps,
Julian
I hope this helps,
Julian
- Doum
Re: Naxo, Snaxo - réglage, entretien
Déjà merci pour ces informations. Petite question, j’ai lu que les réglages d’origine étaient marqués sur les SNAXO ?
Bon je suis en vacances là mais il ne me semble n’avoir rien remarqué de tel sur le mien.
Cela se manifeste comment ?
- Nac-nap21
Comme indiqué dans la procédure, avant toute manipulation il faut faire un repère de la position initiale des potentiomètres à l'aide d'un feutre à pointe fine.First, mark the pots starting position before you start with a fine point felt tip marker.
- Doum
Merci,
Mais mon idée était autre ! J’ai eu ce Snaxo d’occasion. Tout fonctionne à merveille mais j’ai une très légère impression de dissociation entre les fréquences qui nuisent un peu à la fluidité de l’ensemble. Je me dis que les réglages d’origine ont peut être été changés ?
Une question me taraude. Si les Snaxo sont fait pour les SBL, leur réglage d’origine l’est egalement. Si je comprends bien, il s’agit d’envoyer les bonnes fréquences aux bons hauts-parleurs ?
Pourquoi vouloir changer cela puisque c’est le meilleur réglage ? La pièce ne change rien à cela. Pour une enceinte a filtres passif, on ne va pas s’amuser à dérégler ce qu’a fait le constructeur ?!!! Donc pourquoi cela serait-il différent avec l’actif ? Ça reste une enceinte...
Parce que du coup on risque de supprimer certaines fréquences...
Je me trompe ?
Je me trompe ?
Je crois que les réglages influent sur les niveaux de grave et d'aigu, pas sur la fréquence de coupure.
Ok ces réglages sont faits d'usine, mais la disparité de fabrication des composants, ainsi que la finesse potentielle de l'actif font que ces disparités de fabrication sont audibles et que pour atteindre l'équilibre parfait des réglages fins sont nécessaires
- thierry931
Ce réglage est utile pour régler les niveaux de sorties du Naxo pour chaque HP, cela ne change pas les fréquences de coupures.
Cela te sert pour peaufiner et adapter surtout le résultat en fonction de la pièce d'écoute, qui tout de même a toujours une influence sur l'équilibre.
Tu peux donc le régler toi-même, J.Vereker l'avait indiqué.
ChriS.P.L a fait ces réglages dernièrement pour son ( ancien ) système actif, tu devrais faire une recherche.
- Doum
Ok, je comprends mieux.
Merci !!
Merci !!
danielw4
Les fréquences de coupures sont gérés par les différentes cellules qui fonctionnent comme un pré ampli.
Les trimmers font office de potentiomètres, exactement comme un potentiomètre de volume. On peut régler plus ou mois de grave et plus ou moins d’aigu.
Et il n’y a aucun risque à les bouger !!!
- cedric31
Bon, je vais essayer l actif à mon tour , j ai trouvé 3 posts sur le Naxo et j ai compris que sur ces filtres les trimmers servent à ajuster le gain pour chaque fréquence HFR HFL LGR LFL de manière à s adapter à l acoustique de la pièce et de rendre l ensemble cohérent par une continuité ressentie entre les HF et les BF
Par contre il n est pas possible de faire le réglage de la fréquence de coupure ce qui signifie que les composants d origine sont choisis afin d avoir la bonne fréquence de coupure sur les 2 voies et que le remplacement de composants devraient déstabiliser l ensemble (peut être l origine des difficultés rencontrées en actif).
Certains d entre vous ont ils essayé de mesurer cette fréquence de coupure sur un Naxo ?
le Naxo semble utilisable de ce fait uniquement avec des enceintes Naim qui ont toutes la même fréquence de coupure , est ce exact ?
Bon dimanche …. Allez le XV de France
Naim
- Doum
Oui les Snaxo sont fait pour la SBL ou Sara (rare) ou DBL ou Iso. J’en ai pour ma part un pour Isobarik mais une voix dysfonctionne… j’avais demandé à Naim de me dire pour qu’elle enceinte il avait été conçu…j’avais eu une réponse très rapidement !!
- cedric31
Merci c'est bien ce que j'ai compris ...
Savez vous , disposez vous des réglages du Naxo/SNaxo en fonction du type d'enceinte ? Quels composants à remplacer , quelles valeurs ?
Je suis preneur du retour d'expérience sur ce sujet.
Naim
- naim21
A l'origine, Dominique avait publié ce post pour rappeler que les potentiomètres des NAXO sont à "désoxyder" par manœuvre de temps en temps.
S'ils permettent, bien évidemment, de régler les niveaux, relatifs comme absolus, des différentes voies dudit filtre, ils DEVRAIENT être régulièrement manipulés afin d'assurer une parfaite conductivité électrique.
L'écoute de ses SBL, en actif donc, avait montré une atténuation évidente de certaines plages de fréquences.
Cette action sur les potars avait remis les choses d'aplomb.
Bon maintenant, plus vraiment de soucis, les SBL ayant été remplacées par des MD3.
Le filtre NAXO a été, de ce fait, refait par Eddy et les cellules de filtrage adaptées.
- Rouxousou
j'ai eu qq mois un système actif...
je n'ai jamais réussi à le régler correctement. je n'ai ni l'oreille, ni la patience pour cela.
Et j'avais tendance à toujours tripoter les réglages possible à la recherche d'un meilleur équilibre. j'en arrivait a écouter le système et plus la musique.
l'horreur.
Bref le retour à un intégré a été très rassérénant.
Ce n'est que ma pitoyable et courte aventure. Mais cela peut aussi être une mise en garde, car ce n'est pas aussi trivial que ça l'actif !
tcho
l'horreur.
tcho
Les Trimmers agissent comme des atténuateurs de niveau sonore, les réglages d'usine sont équilibrés/marqués dans la première moitié de la rotation du réglage, celle qui atténue le moins. A partir d'un niveau d'atténuation des Trimmers, l'actif perd de son intérêt, d'autant que les contacts peuvent également ternir tout en intensifiant le filtrage. Il m'est toujours apparu que comparé au filtrage passif, l'actif justifie un niveau de réglage du bouton de volume plus élevé,probablement conditionné en partie par l'effet de réglage des trimmers.
Effectivement l'opération de "décrassement" des Trimmers par de multiples rotations de la course est importante. Un Snaxo 242 que j'avais acquis d'occasion, par ailleurs en parfait état de conservation externe et interne, ne fonctionnait pas sur les Médium/Grave d'un canal totalement muet sans raison apparente,
Un brin de curiosité sur le réglage rotatif des Trimmers m'a ensuite permis de découvrir que du signal passait, du coup avec un bon rodage de plusieurs rotations Aller/Retour le Snaxo 242 était complètement rétabli.
- cedric31
Le passage à l actif est intéressant, cela ne m’a pas paru particulièrement difficile de régler le Naxo avec une approche un peu méthodique.
Les trimmers permettent d atténuer le niveau du signal reçu en entrée avant d être filtré et amplifié à nouveau.
La rotation dans le sens horaire atténue la valeur de la résistance et le niveau sera plus élevé.
J ai procédé à un premier relevé de mesure de chaque trimmer qui a révélé une dissymétrie ressentie à l écoute.
Puis après équilibrage et en fonction de la pièce j ai (réglage par pas successif de 0,2 Kohms) trouvé mon équilibre entre les graves et les aigus ( montage horizontal)
Mon réglage final est de 12.2 Kohms pour les aigus et de 9,6 Kohms pour les graves … et sur plusieurs types de musique l équilibre est respecté sans que l on sente la moindre coupure entre les aigus et les graves …
Bref c est amusant d autant plus que l actif propose une restitution plus nette, les instruments sont mieux détourés, la musique a pris une certaine liberté à s exprimer…. C est pas mal du tout.
Naim
